Aug 12, 2017 #1 O omerysmi Member level 5 Joined Oct 10, 2014 Messages 91 Helped 0 Reputation 0 Reaction score 0 Trophy points 6 Activity points 1,128 Hi, I've tried to use CA3140AE IC as a buffer, i putted 5v in the (+) pin but the problem is that my output is 3V and not 5V. This is the scheme: Why i don't get 5v in the output in your opinion? CA3140AE datasheet: https://www.intersil.com/content/dam/Intersil/documents/ca31/ca3140-a.pdf
Aug 12, 2017 #2 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,419 Helped 14,749 Reputation 29,780 Reaction score 14,100 Trophy points 1,393 Location Bochum, Germany Activity points 298,094 Re: CA3140AE Op amplifier ic Look for datasheet parameters (At V+ = 5V, V- = 0V) - Common Mode Input Voltage Range - Maximum Output Voltage According to specifications, the buffer can be expected to work between 0.13 and 2.6V The device isn't specified as rail-to-rail OP. Even a rail-to-rail OP buffer won't reach the supply rail voltage exactly.
Aug 12, 2017 #3 O omerysmi Member level 5 Joined Oct 10, 2014 Messages 91 Helped 0 Reputation 0 Reaction score 0 Trophy points 6 Activity points 1,128 Re: CA3140AE Op amplifier ic FvM said: Look for datasheet parameters (At V+ = 5V, V- = 0V) - Common Mode Input Voltage Range - Maximum Output Voltage According to specifications, the buffer can be expected to work between 0.13 and 2.6V The device isn't specified as rail-to-rail OP. Even a rail-to-rail OP buffer won't reach the supply rail voltage exactly. Click to expand... Do you know another ic which will help me to make it? maybe lm741 or lm358? Last edited: Aug 12, 2017
Aug 12, 2017 #4 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,419 Helped 14,749 Reputation 29,780 Reaction score 14,100 Trophy points 1,393 Location Bochum, Germany Activity points 298,094 Re: CA3140AE Op amplifier ic None of the mentioned classical OPs provides rail-to-rail operation. You need to look for more recent types, each vendor has suitable types.
Aug 12, 2017 #5 O omerysmi Member level 5 Joined Oct 10, 2014 Messages 91 Helped 0 Reputation 0 Reaction score 0 Trophy points 6 Activity points 1,128 Re: CA3140AE Op amplifier ic FvM said: None of the mentioned classical OPs provides rail-to-rail operation. You need to look for more recent types, each vendor has suitable types. Click to expand... This is good right? https://www.st.com/content/ccc/reso...df/jcr:content/translations/en.CD00001188.pdf
Aug 13, 2017 #6 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,419 Helped 14,749 Reputation 29,780 Reaction score 14,100 Trophy points 1,393 Location Bochum, Germany Activity points 298,094 Yes, one of many suitable rail-to-rail OPs.
