[MOVED] Boolean implementation using multiplexer
sunidrak
Full Member level 1
Bengaluru, India
hi,
how to implement this using mux??
f(A,B,C)=A+(Abar)B using 4:1 Mux
i knw how to implement F(A,B,C)=Σ(0,1,5,6) using 4:1 Mux
my question is how to bring the reduced form of boolean expression to its original form , so to implement it using Mux??
Re: Boolean implementation using multiplexer
Seems simple to just spell-out the four function possibilities like this ...
A | B | Y | MUX-input
0 | 0 | 0 | In0
0 | 1 | 1 | In1
1 | 0 | 1 | In2
1 | 1 | 1 | In3
The Y column is the tied-off level at the four corresponding MUX inputs.
And then A feeds into Select1 and B feeds into Select0 of the MUX.
But this seems too obvious and I must be misunderstanding the real question?
