dopeydavoid298
Newbie
Hi all!
I'm hoping someone has seen something similar or the solution is obvious.
We have multiple AC/DC SMPS (lab power supplies) at ratings at ratings of 400W, 1500W and 2X 600W all rated at "100-240" (max 265VAC in manual) that have had the fuses or MOVs fail (MOVs all measured <50ohm on the multimeter). These supplies range across two different manufacturers.
All supplies have CV/CC/CP settings and our grid voltage is 244-250 at the outlet. These incidents have occurred at different buildings on the site and in different configurations on the output.
In all cases, the trigger has been impulse current events on the 18-30V outputs. The first was inrush on the output of two devices that simultaneously died, and the next two were the 2x parallel connection attempts of 600W models (module 1 off and module 2 on, connect together, module 1 on, module 1 dies during balancing surge- Parallel works okay otherwise and follows manuals master/slave config).
In all cases the input fuses audibly explode (do not rupture) and the MOV either ruptures or measures low impedance. I'm suspecting input voltage ringing from the sudden application/removal of a huge load as our grid is high relative to overall operating range.
Does anything obvious come to mind? I can't see how else anything on the output of CV/CC/CP lab power supply can blow the input MOVs?
(I do have a device with 50kHz bandwidth that will convert the grid voltage to a 0-1V output for scope measurement.)
Dave
Dave
