Motor circuit breaker or VFD delayed overcurrent limiting is good for most general purpose applications. If you are operating a motor with temporary overload or a VFD with high torque in the low rpm range, an exact winding temperature monitoring is preferred.
Klaus gave you and example with ventilation I believe. The motor may operate fine but due to low air flow will heat up. This condition I think would cause a drop in current.
