Note: This feature currently requires accessing the site using the built-in Safari browser.
john.l said:what is the purpose of L293D and cost ? is there any alternative for this ic ?
rushi53 said:john.l said:what is the purpose of L293D and cost ? is there any alternative for this ic ?
Purpose motor needs 12 volts power supply and output of microcontroller is 5 volts. This ic acts like converter(actually its not convertor but for simplicity u can consider.)
cost in pune,india it will cost near Rs.100/-
alternative u can use transistor circuit. but it will be large size and complex as compare to 293, so i will suggest 239
Let me know if you need any more help
__________________
Thanks,
Rushikesh
www.projectsof8051.com
