feel_on_on
Full Member level 5
Most accurate : setup and hold in each corner:separate calculated
OCV libraries
set_operating_conditions
-analysis_type on_chip_variation
-max_lib WORST_LIB
-max WORST_OC
-min_lib WORST_LIB_OCV_min
-min WORST_OCV_min
Why is it the Most accurate OCV set?
If chip worked at best operation condition,It should use best min library and best max library for timing analyze.If you use two library ,best max library and worst min library for OCV timing analyze, is it accurate?
OCV libraries
-max_lib WORST_LIB
-max WORST_OC
-min WORST_OCV_min
