I can not really calculate switching and conduction losses at IGBT.
The conduction loss for any device (mechanical switch, MOSFET, IGBT...):
P_tot = U x I (during ON state)
(Where:
U is the voltage across the device during ON time
I is the current through the device during ON time)
If you have a PWM signal, then the duty_cycle comes into play. Where duty_cycle is the percentage of ON time in relation to the total time.
P_tot = U x I x dutyCycle
Usually you know the value of "I" of your application. Then with the use of "I" you should fing the corresponding "U" in the datasheet)
Try this and come back with the values and results.
BTW: Each IGBT manufacturer and each MOSFET manufacturer and each gate_driver manufacturer should have application notes about how to calculate the losses.
Sooner or later you should read through them. I recommend to do it "sooner" ;-)
Klaus
