michalk
Newbie level 5
- Joined
- Feb 24, 2011
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,362
Hobbyist here, and my first post.
I need to implement an ideal switch in a MOSFET. This is in a vehicle with multiple batteries, and I would like to manage these with the following functions:
1) Isolate a battery
2) Join the batteries
I made a PC board with ST Micro VN31, which is an IC SSR; basically the charge pump and other bits with a MOSFET in a single package. My board works exceptionally well, except that I'm not getting isolation. When I isolate a low voltage battery, the bus voltage becomes higher than the isolated battery, causing current to reverse flow through the intrinsic body diode.
I need to build another board with the FETs back-to-back, but I was wondering if I could simplify with something like this:
It's a two channel version of a solid state relay.
Can I connect Batt1 to out1, and bus to out2? I would leave Vcc floating.
So the idea is that when enabled conducting in a normal situation, curent would flow backwards through FET1, to VCC which is internally connected to FET2, then forward current through FET2 and then out to the bus.
When not enabled (not conducting), high voltage on the batt would try to drive current through FET1 through the body diode, but would hit FET2 that is not coducting.
The data sheets that I can find don't have any examples using it this way. Is there a problem with trying to do this?
