Aazim
Newbie level 3
Assalam 0 Alaikum!
I'm designing an H-Bridge Stepper Driver circuit using MOSFET IRF3205. I'm having a lot of troubles in doing so, since last 3 weeks. Still no result..
Actually, the major problem is that, the upper side of the circuit(i.e the supply side FETs) are getting hot enough. The main Supply is 12V DC. Also, the supply at the output terminals to the motor, the FETs are giving is 7Volts approx.
Please help me..
Thanx in advance
I also tried with the irf4905(P-channel) in complement with irf3205(N-channel).. If you have the solution using the complementary logic, please tell that also..
I tried the circuits available on Internet also, but none of them helpful to me.
The problem is same with both the cases.
Please help me..
Thanx in advance
