If I remember correctly, it was Latin hypercube.
What is the number of bins in Latin? how you select the optimum number
Thank you again
Latin HC gives better result when you have limited resources to run very high number of simulations. But random sampling is useful if you found troubles, because with random sampling easy to repeat that condition where an issue occured. As I remember with Latin HC it wasn't possible because it uses previous run settings from run to run, and to repeat a condition you have to repeat all the previous runs.
But just to find sigma Latin HC is better.
I run 1000 sims if they quite fast, and to estimate sigma of very slow simulations sometimes 30 run is enough.
Is the reason behind it to have statistic infromation about the Yield or other advantagues of MC over the Worst case corners?
