I am trying to design a monopole PCB antenna using HFSS. However, I am not familiar with the software as well as concepts of monopole.
1. regarding the HFSS, any friends knows how to create a right structure? I use a thinkless rectangle to simulate the monopole, a box to simulate FR4 PCB, and another sheet to simulate the ground. Both ground and monopole i set to perfect conductor. Then I put a large sphere outside and set to radiation boundary. After that i set a lumped port btn the monopole and ground. However, I was only able to see the S11, but don't know how to view the radiation pattern.
2. in my understanding, monopole is 1/4λ, the frequency is 900M, so λ=33cm, 1/4λ=8.25cm, with ξ=4.4, i use the ADS LineCalc to calculate the length and width of the monopole. However, the results deviated a lot and reach 1.4GHz. Anyone knows how to calculate monopole dimension with PCB substrate?
Help needee! Thanx with regards
JY
