modulo operator doubt
vinodkumar
Full Member level 5
Full Member level 5
hyderabad
xst:1763
HI friends IS modulus operator,x modulo y is synthsizable,i find it not where x and y are integers,then how to get synthesizable HW for modulo operator.
byeee
hi
yes synthesizable.:idea:
for integer and std_logic_vector work, for real not ok
Hi i wrote the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.std_logic_unsigned.all;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity modulo is
port(a,b:in integer;
c:eek:ut integer
end modulo;
architecture Behavioral of modulo is
begin
c<= a mod b;
end Behavioral;
the error i got is:
ERROR:Xst:1763 - "D:/modulo/modulo/mod.vhd" line 42: Operator <MODULUS> must have constant modulo operand.
Your error means that you cannot have 'b' as variable, and b cannot be anything other than a power of 2. If you do
c<= a mod 2 or
c<= a mode 2^n.
Kr,
Avi
http://www.vlsiip.com
hi actually i want to do a mod 100,a mod 1000 like tht.byee
