funjoke
Member level 3
d flip flop
module dff
(output reg op_q,
output op_q_n,
input ip_data,
input ip_aset_n,
input ip_areset_n,
input ip_clock);
Write a behavioural description of the D flip flop(DFF) that fulfils the following specification
-The DFF is synchronised to the rising edge of a clock
-The DFF has an active-low asynchoronous reset
-The DFF has an active-low asynchoronous set
-The reset has priority over the set
The answer is :
always@(posedge ip_clock)
if(!ip_areset_n)
op_q<=0;
else
op_q<=ip_data;
i dunno know how to do it le ,can anybody help ?
module dff
(output reg op_q,
output op_q_n,
input ip_data,
input ip_aset_n,
input ip_areset_n,
input ip_clock);
The answer is :
if(!ip_areset_n)
op_q<=0;
else
op_q<=ip_data;
