modulation is DQPSK - Symbol duration
yassine88
Newbie level 5
Newbie level 5
hello,
in the case of the transmission without coding rate ( r=1/2)
I want to calculate the relationship between Ts (symbol time) as a function of Tb (bit duration) in modulation is DQPSK (Differential Quadrature Phase Shift Keying).,
thank you very much
QPSK/DQPSK is 2bits/symbol, so symbol time Ts = 2Tb; however in reality, note that "bit duration" is not really accurate here since both bits are sent simultaneously. It makes more sense to talk about bitrates, and DQPSK has double the bitrate compared to BPSK (which is 1bit/symbol), assuming the same symbol rate.
It makes sense define Ts as "symbol time" and Tb as "bit time" (not bit duration).
They are the inverses of symbol rate and bit rate respectively.
Regards
Z
hello,
thank you very much for yours answers.
other question : in case of transmission with coding rate ( r=1/2), what is relation between Ts and Tb
thank you very much .
To get the effective bitrate for a given coding rate, you can just multiply it by the number of bits per symbol. So for QPSK/DQPSK we have 2 coded bits/symbol and 1/2 information bit/coded bit, giving 1 information bit/symbol, meaning Ts = Tb.
