deepu_s_s said:Hi ,
R u using a genuine modelsim?
muhammad_ali said:yes it seems error due to license. is this your first time dealing with modelsim?
if not: the license depends on your host id (or your physical address if you r using windows), so have you changed your host id (or your physical address)?
muhammad_ali said:r u using Modelsim only or you use another tools from Mentor?
because if you are using Modelsim only you can launch "license wizard test". you can invoke this wizard by:start --> programs -->Modelsim... --> licensing wizard.
this wizard guides you to test your license validity.
also it seems you r using license remotely. so make sure for your connection with the server that provides you with this license as gck told you.
muhammad_ali said:well i don't how the modelsim can generate a license. but i am sure that getting a license for the modelsim can't be issued so. any way, to operate the modelsim(or any mentor graphics tool) you need a license file (such as license.dat you got previously) this license depends on your machine physical address. so if the physical address doesn't coincide with the one that is written in the license file, the tool will not operate then. so this is the first thing you have to check.
so oopen the license file you have as a text file then you will find a line start with SERVER then your machine name then the machine physical address.
check this and tell me
ruwanika said:thanks .can u send me the link that I should follow to det this?I tried to get this.what is this starter version?its capacity is 201mb.my previous Modelsim XE ii 5.7c is only 66MB .is this starter version is compatible with xilinx ISE 7.1i?
