-- C:\XILINX\GATE
-- VHDL Annotation Test Bench created by
-- HDL Bencher 6.1i
-- Tue Aug 30 15:55:10 2005
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.NUMERIC_STD.ALL;
USE IEEE.STD_LOGIC_TEXTIO.ALL;
USE STD.TEXTIO.ALL;
ENTITY ee IS
END ee;
ARCHITECTURE testbench_arch OF ee IS
-- If you get a compiler error on the following line,
-- from the menu do Options->Configuration select VHDL 87
FILE RESULTS: TEXT OPEN WRITE_MODE IS "c:\xilinx\gate\ee.ano";
COMPONENT gate
PORT (
a : In std_logic;
b : In std_logic;
clk : In std_logic;
q : Out INTEGER RANGE 0 TO 7;
ea : In std_logic;
y : Out std_logic
END COMPONENT;
SIGNAL a : std_logic;
SIGNAL b : std_logic;
SIGNAL clk : std_logic;
SIGNAL q : INTEGER RANGE 0 TO 7;
SIGNAL ea : std_logic;
SIGNAL y : std_logic;
BEGIN
UUT : gate
PORT MAP (
a => a,
b => b,
clk => clk,
q => q,
ea => ea,
y => y
PROCESS -- clock process for clk,
VARIABLE TX_TIME : INTEGER :=0;
PROCEDURE ANNOTATE_q(
TX_TIME : INTEGER
) IS
VARIABLE TX_STR : String(1 to 4096);
VARIABLE TX_LOC : LINE;
BEGIN
STD.TEXTIO.write(TX_LOC,string'("Annotate["));
STD.TEXTIO.write(TX_LOC, TX_TIME);
STD.TEXTIO.write(TX_LOC,string'(",q,"));
STD.TEXTIO.write(TX_LOC, q);
STD.TEXTIO.write(TX_LOC, string'("]"));
TX_STR(TX_LOC.all'range) := TX_LOC.all;
STD.TEXTIO.writeline(results, TX_LOC);
STD.TEXTIO.Deallocate(TX_LOC);
END;
PROCEDURE ANNOTATE_y(
TX_TIME : INTEGER
) IS
BEGIN
STD.TEXTIO.write(TX_LOC,string'(",y,"));
IEEE.STD_LOGIC_TEXTIO.write(TX_LOC, y);
END;
BEGIN
CLOCK_LOOP : LOOP
clk <= transport '0';
WAIT FOR 10 ns;
TX_TIME := TX_TIME + 10;
clk <= transport '1';
WAIT FOR 10 ns;
ANNOTATE_q(TX_TIME);
ANNOTATE_y(TX_TIME);
WAIT FOR 40 ns;
TX_TIME := TX_TIME + 40;
WAIT FOR 10 ns;
END LOOP CLOCK_LOOP;
END PROCESS;
PROCESS -- Process for clk
VARIABLE TX_OUT : LINE;
BEGIN
a <= transport '0';
b <= transport '0';
ea <= transport '0';
WAIT FOR 70 ns; -- Time=70 ns
a <= transport '1';
ea <= transport '1';
WAIT FOR 70 ns; -- Time=140 ns
a <= transport '0';
b <= transport '1';
WAIT FOR 70 ns; -- Time=210 ns
a <= transport '1';
WAIT FOR 70 ns; -- Time=280 ns
a <= transport '0';
b <= transport '0';
WAIT FOR 140 ns; -- Time=420 ns
b <= transport '1';
WAIT FOR 140 ns; -- Time=560 ns
a <= transport '1';
WAIT FOR 70 ns; -- Time=630 ns
b <= transport '0';
WAIT FOR 80 ns; -- Time=710 ns
STD.TEXTIO.write(TX_OUT, string'("Total[]"));
STD.TEXTIO.writeline(results, TX_OUT);
ASSERT (FALSE) REPORT
"Success! Simulation for annotation completed" // this is the 144 line
SEVERITY FAILURE;
END PROCESS;
END testbench_arch;
CONFIGURATION gate_cfg OF ee IS
FOR testbench_arch
END FOR;
END gate_cfg;
