vivo_m
Member level 3
hello everybody,
i'm trying to simulate my vhdl file using modelsim but actually it is taking the input value in hex format..
i.e at the wave window, when i right click my input port and choose force, "32'hXXXXXXXX" is wrote in the value field..
i don't know what to do to make it "uuuuu..." and accept binary value..
any idea how can i overcome this plzzzz
beside that i'm getting this warning when start simulation
# Loading work.testing_sim(behavioral)
# ** Warning: Design size of 18505 statements or 1 leaf instances exceeds ModelSim PE Student Edition recommended capacity.
# Expect performance to be quite adversely affected.
after forcing the input signals to its proper value.. i got this warning
# ** Failure: ARG is too large in CONV_INTEGER
# Time: 100 ns Iteration: 0 Process: /testing_sim/line__49 File: E:/vhdl_Code/testing_sim.vhd
# ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).
# Time: 100 ns Iteration: 0 Instance: /testing_sim
# ** Warning: CONV_INTEGER: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, and it has been converted to 0.
and simulation stops at a line that i'm dividing 2 variables, each of size (32*2) std_logic_vector, i'm converting them into integer value using conv_integer() function to apply division operation
i tried to make them 32 only but i got this error
# ** Fatal: (vsim-3977) Integer divide by zero.
# Fatal error in Process line__49 at E:/vhdl_Code/testing_sim.vhd line 86
although i'ven't set any of the values to zero..
i'm using Modelsim PE 10.2
any help plzzzz.....
thanks...
thanks...
