Modelsim error: vlog-2110 illegal refence to net error
hazardcell
Newbie level 3
vlog-2110 error
Whenever I try to compile the code in modelsim I get a "vlog-2110 illegal refence to net error" for the lines
l_prev = l_next;
      r_prev = r_next;
      k_prev = k_next;
basically, I need to run round 16 times (DES) and the value output in l_next from the previous iteration should be the l_prev for the current one. similarly for r_prev and k_prev. However I keep getting that error. I'm a newbie to verilog so please go easy on me :)
Also for some reason "i" never changes, it just remains as 0000 throughout. any help appreciated. thanks in advance
wire [63:0] r2;
  wire [31:0] l_prev;
  wire [31:0] r_prev;
  wire [55:0] k_prev;
  wire [31:0] l_next;
  wire [31:0] r_next;
  wire [55:0] k_next;
  split3 t1( .r0(r_prev), .r1(l_prev), .x(r2) );
  PC1    t2( .r(k_prev), .x(k) );
  round  t3( .l_prev(l_prev), .l_next(l_next), .r_prev(r_prev), .r_next(r_next), .k_prev(k_prev), .k_next(k_next), .i(i) );
  initial @ ( posedge clk, posedge req )
  begin
    if( req == 1 )
    begin
      m = M;
      k = K;
      i = 4'b0;
    end
  end
  always  @ ( posedge clk, posedge req )
  begin
    if( i < 4'b1111 | i == 4'b1111 )
    begin
      i = i + 1;
      l_prev = l_next;
      r_prev = r_next;
      k_prev = k_next;
    end
  end
Added after 10 minutes:
OK the problem with "i" was a bit stupid. I just forgot to test it with a clock. Still can't figure out the other one though
Re: vlog-2110 error
Shouldn't l_prev, r_prev, and k_prev be defined as reg?
    hazardcell
vlog-2110 error
if they were then they wouldn't be accepted as outputs for PC1 and split3
vlog-2110 error
So you have multiple things driving those signals? Doesn't seem like a good idea.
Re: vlog-2110 error
If I declare l_prev r_prev and k_prev as regs, could I then assign them to the outputs of k_next l_next and r_next?
Re: vlog-2110 error
no problem
    hazardcell
Re: vlog-2110 error
Managed to get it working. Thanks guys
