Modelsim 6.0 and compxlib (ISE 5.2)
bibo1978
Full Member level 4
compile compixlib in modelsim 6 se
I have ISE 5.2 and compxlib didn't compile with ModelSim 6.0 SE, can any one tell me how to compile Xilinx models with Modelsim 6.0 SE.
compxlib modelsim
u must import xilinx std cell library in modelsim 6 se.
extrat all library from xilinxmodelsim 5.7 then import in modelsim 6 .
bye
how to compile in modelsim 6.0
yes it is compatible.. am currently using ISE 6.2 and am using modemsim 6.0 SE, its very good.. wonderful.. am using i dunt think there is any problem.. like wot aravind said.. jes import the xilinxs FPGA library into modelsim lib it wud surely work fine without any problem.. u might find it difficult to get ASIC library.. give it a shot
with regards,
compxlib +pdf
I don't have modelsim 5.7 SE I have XE but I doubt that the XE library will include smartmodels?
anyhow I will try importing from XE and will check if the smart models are there.
compxlib modelsim 6
Hi
Maybe these papers will help you how to compile libs manualy:
http://www.model.com/fpga/documents/113_xilinx.pdf
and take a look at this script:
f-p://ftp.xilinx.com/pub/swhelp/mti/xilinx_lib_5.tar.gz
Hope this helps
Cheers
