The transistor level specifications would depend on the OTA architecture you are using.
But, in general OTA is similar to any TA; TA amplifies single-ended signals whereas the difference of two signals will be amplified in an OTA.
* The gain of OTA is still Gm*Ro
* slew rate is Imax/Cload
etc.
I would follow the following procedure: identify the architecture, build a small signal model, identify how the specifications (like gain, slew rate, etc) depend on the transistors and get the transistor-level spec.
