model or conver pressure to viltage signal
javad ahmadi
i have a mems microphone that i transfer this microphone model to the ADS.this microphone capcitance change with pressure(sound level).for modeling this microphone i need to understand that this microphone how to convert pressure to signal?
please help me for modeling pressure to voltage.
for example 1pa----------------(?)mvolt generated
or 1pa equivalent how volt or mvolt?
In order to understand this phenomena, look at the formulae about "capacitance between two plates"..
Then extract what happens over there ...
please help me for this formulae.i dont understand that this microphone how generated voltage for 1pa pressure
please help me for modeling this microphone in ADS
microphone is a variable capacitor vesus pressure
this capacitor how modeling in th ADS?
Hi Javad
I think you're referring to a capacitive microphone . if yes , what is the problem ? when your sound is coming through the plates , thus their distance will be changed ( distance between two plates ) . and thus capacity will be changed .
Hence when you tie it to the DC supply ( via a resistor ) you'll have a variable DC voltage across your microphone . ( that is like your sound ! )
I hope you got the point
Best Wishes
Goldsmith
Hi Javad
Best Wishes
Goldsmith
hi goldsmith
thanks for your help
but i dont know that bias thic capacitive microphone and simulation its in the ADS
I need a interface cicuite to connect this capacitive microphone to the preamplifiers;
and how simulation this capacitive microphone in ADS as a variable capacitance?
thia means for this input capacitve microphone how simulation pressure that generated voltage in output microphone?
