farishamam
Newbie level 6
can the transmitter of a mobile phone connected to an amplifier produce a 12v, 900MHz signal?
Yes...it can be used but with a lot modifications, and the power output will depend on the output module which may not be more than 1 watt. As in practical, mobiles communicate with towers which are equipped with more sensitive receivers, the low power of the handset will work fine.can the transmitter of a mobile phone connected to an amplifier produce a 12v, 900MHz signal?
