[SOLVED] "mnemonic expected" error
bluerose
Newbie level 3
Newbie level 3
hello
I have this error due to my assembly debugging in keil uvision4 for infineon c167cs device:
main.c(15): error C195: inline-asm: Mnemonic expected
does anyone know what it is about??
Without your code, I'd guess it's a syntax error; maybe missing a semicolon on an earlier line; something like that.
If you are doing inline asm coding in your c/c++/pascal code then you have to put the asm code inside the inline asm block something like
Code C - [expand]
8
9
asm{
or
_asm{
It is different for different compilers. See help of your compiler about inline asm.
