blacksnow
Junior Member level 2
I am learning the PIC microcontroller and trying to simulate some of the project programs of the book “Advanced PIC18 Projects in C by Dogan Ibrahim”. Nowadays I am working on Interfacing of SD Card with PIC18f4520 (in proteus simulation only).
I copied the following code from the book to mikroC Pro for PIC Compiler. The Compilation/Creation of Hex file was successful but when I try to simulate using proteus the program goes into halt/hang state in proteus and the pin status of SD Card in proteus is also of grey color (Neither green nor red).
I connected the PIC18f4520 with SD Card in proteus. Created an image file with .mmc extension using WinImage software and provided the path of the image file to SD card’s properties in proteus.
The proteus design works well till the fat initialization but when I add the quickformat function to the code the design does’nt do anything even it does not display any sent messages on uart (The file MYFILE.TXT is also not created in the image file when it is mounted).
The messages on uart are displayed successfully without the quickformat instruction.
Please provide me some solution or some suggestion. Also tell me if there are any other instructions required before the quickformat instruction.
char filename[] = "MYFILE55TXT";
unsigned char txt[] = "This is the added data...";
unsigned short character;
unsigned long file_size,i;
void main()
// Configure the serial port
Usart_Init(2400);
// Initialise the SPI bus
Spi_Init_Advanced(MASTER_OSC_DIV16,DATA_SAMPLE_MIDDLE,CLK_IDLE_LOW, LOW_2_HIGH);
// Initialise the SD card bus
while(Mmc_Init(&PORTC,2));
// Initialise the FAT file system
while(Mmc_Fat_Init(&PORTC,2));
//---------------------------------------------------The simulation works well till this line -----------------------------------------------------------
Mmc_Fat_QuickFormat(“AAA”));
// Create the file (if it doesn’t exist)
Mmc_Fat_Assign(&filename,0x80);
// Clear the file, start with new data
Mmc_Fat_Rewrite();
// Write data to the file
Mmc_Fat_Write("This is MYFILE.TXT.",19);
// Add more data to the end...
Mmc_Fat_Append();
Mmc_Fat_Write(txt,sizeof(txt));
// Now read the data and send to UART
Mmc_Fat_Reset(&file_size);
for(i=0; i<file_size; i++)
Mmc_Fat_Read(&character);
Usart_Write(character);
for(;;); // wait here forever
