tonal
Newbie level 6
Hi all!
Hope I'm writing in the right place.
I'll get straight to the point.
In a product we have an issue with a component (a MLCC cap) in the SMPS part of the PCBA.
Although the PCBA and the component itself are tested (ICT and FVT tests) by our supplier and also in the company I work we perform functional tests in the finished product we get this kind of failure in a sampling process where the product is tested under real life conditions and we had also a couple of incidents in the field.
The cap is placed near (1mm) and parallel to the edge of the PCB. There are no depanelization points very close to the cap (the closest point were the PCBA is attached to the PCB frame is around 6cm away).
The PCB is around 150x150 and 0.8mm thick.
The depanelization of the PCBA takes place in the supplier after reflow and before through-hole parts assembly.
I was wondering whether this failure is due to a faulty part or due to bad handling/stress during depanelization.
One thought that I had was that the capacitor is mechanically stressed, cracks and after some time during operation (after a couple of hours) it fails (a resistance of a couple hundred Ohms is measured between the two terminals). There is no electrical stress applied to the cap.
Can you think of any other reasons that a ceramic multilayer cap shorts in the first hours of its operation?
