azone2
Newbie level 5
I'll try to describe my question as simply and precisely as I can.
My direct question concerns the control lines from the microcontroller that will control the analog switches on the analog board.
If I'm running the control lines from the digital board to the analog board, shouldn't there be a ground return path from the analog board to the digital board for each or all of these control lines?
Otherwise, if I don't give the control lines some sort of return path, won't they interfere/spike analog ground as they fight their way back to 'see' digtial ground and possibly result in audible spikes in the analog circuitry?
Is the control input on a typical analog switch electrically isolated? (part spec'd in this design is DG409).
- I have a mixed signal audio design consisting of analog audio circuits controlled by a microcontroller and analog switches.
- The analog switches control fixed routing as well as some slow speed gating and switching stuff.
- The analog switches must be on the analog board.
- The microcontroller resides on a separate digital board.
- The analog switches are grounded to analog ground on the analog board.
