Mixed ground planes:
Hello,
I'm working on the redesign of a noisy BLDC motor driver. On the same board we have sensitive analog (strain gauge, ADC, etc.), a micro-controller and power MOSFETs. To have a good noise immunity, I want to separate my power and ground planes. I read a lot about signal integrity and PCB design. However, before doing the real board I would like some advice to be sure I'm doing it correctly.
Here is an example schematic:
Do you have any comment or suggestion about the way I'm isolating the planes?
Here is the board layout:
Note: the real board will be 4-layers Signal|Gnd|Pwr|Signal but to simplify things I routed this example on 2 layers with only a ground plane. On the actual board there will be a power plane superposed on each ground plane.
Am I doing it right?
Thanks in advance for your comments,
JFDuval
