Mixed core for LLC......Ferroxcube and TDK
cupoftea
Doing 2kW LLC, Vin=390v, Fsw~50kHz.
For the resonant inductor, will use a 3C94 ETD59 ungapped core from ferroxcube, with a 2mm gapped core (N87) from TDK......will this be OK?.....will wind turns and check the inductance factor.
They appear identical WRT core loss and permeability, so it should be just like its an ungapped N87 core half from TDK?
3C94
N87
..i actually dont think its possible to calculate this very accurately, due to the unknown exact extent of the fringing field in the gap and around it.?
Its probably better to say that AL=311 if all ferrite is N87...if the ungapped half is 3C94, then 3C94 's AL value is 13% greater than that of N87, so therefore, halve that (as only one half is 3c94), giving 6.5%....and then say AL with the 2mm gap is 311+ 0.065*311 =~ 331. Would you agree? We will measure it aswell....with home made resonance inductor meter. (but this uses 5% cap, and we cant yet afford accurate capacitance meter)
Your calculation approach is basically incorrect. Total AL value is dominated by air gap reluctance. If ungapped AL varies by average 6.5 %, gapped AL variation will be less than 0.5%.
