Mar 5, 2009 #1 R raviraj.jr Junior Member level 1 Joined Mar 5, 2009 Messages 16 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,283 Activity points 1,394 keil assembly code in c using #pragma I've written a function in assembly and which i've mixed with C code in keil complier using #pragma ASM ------------------ ---------------- #pragma but i'm getting error like this building target'target 1' compiling xyz.c.... target not created why is this happening????
Apr 28, 2009 #2 S samx Newbie level 4 Joined Mar 31, 2009 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,322 keil compiling assembly Hi Boss, To work both assembly and C code you need to 1) add .lib file to group and compile 2) enable Generate assembler src file option in the group. Now your code will work. Regards, Sam
