Neha Anu
Junior Member level 1
Hi all,
I want to miter some nets that are autorouted in specctra(allegro V 16.0).When mitered the some of the nets are mitering to diagonal corners,some others are not even if there are enough space in the board file (same with the case of rounded corners).I changed the setback length as a trail basis to check the behaviour of the miter command.Still the nets are not mitering.
Why the specctra is showing this nonpredictable behaviour?Is there any command that should be set before miter command?Can anyone plss give a solution to this??
Thanks
Neha
Thanks
Neha
