eda_wiz
Advanced Member level 2
Hi folks,
After reporting post layout power in power compiler, I noticed that out of the 2 blocks I have 1 block (SPI) consumes 35% -power and another block(ECG_CQH) consumes less than 1% power. The report doesnt show where does the remaining power goes. ANy idea where is remaining power dissipated? Is it in the clock tree. PS this is final netlist with clock tree. Chk the attached image
Global Operating Voltage = 3
Power-specific unit information :
Voltage Units = 1V
Capacitance Units = 1.000000pf
Time Units = 1ns
Dynamic Power Units = 1mW (derived from V,C,T units)
Leakage Power Units = 1pW
Attributes
h - Hierarchical cell
Cell Driven Net Tot Dynamic Cell
Internal Switching Power Leakage
Cell Power Power (% Cell/Tot) Power Attrs
SPI 0.1002 N/A N/A (N/A) 7180.7515 h
SCLK__L1_I0 0.0309 0.0196 5.06e-02 (61%) 180.7207
SCLK__L2_I0 0.0267 2.180e-03 2.89e-02 (92%) 141.2095
SCLK__L2_I1 0.0266 2.647e-03 2.93e-02 (91%) 141.2095
SCLK__L3_I0 0.0242 0.0249 4.91e-02 (49%) 141.2095
SCLK__L3_I1 8.337e-03 2.180e-03 1.05e-02 (79%) 122.5979
SCLK__L2_I2 8.293e-03 0.0115 1.98e-02 (42%) 109.9792
ECG_CQH 1.000e-03 N/A N/A (N/A) 146898.7500
h
WCLK__L2_I4 2.965e-06 2.701e-07 3.23e-06 (92%) 174.4204
WCLK__L2_I3 2.962e-06 2.976e-07 3.26e-06 (91%) 174.4204
WCLK__L4_I1 2.900e-06 4.446e-07 3.34e-06 (87%) 174.4204
WCLK__L3_I3 2.897e-06 4.774e-07 3.37e-06 (86%) 174.4204
WCLK__L3_I2 2.836e-06 1.100e-06 3.94e-06 (72%) 174.4204
WCLK__L2_I6 2.831e-06 1.540e-06 4.37e-06 (65%) 174.4204
WCLK__L1_I0 2.670e-06 2.823e-06 5.49e-06 (49%) 174.4204
WCLK__L5_I0 2.356e-06 5.240e-07 2.88e-06 (82%) 135.9050
WCLK__L3_I1 2.350e-06 7.123e-07 3.06e-06 (77%) 135.9050
WCLK__L2_I2 1.923e-06 2.976e-07 2.22e-06 (87%) 101.7862
WCLK__L2_I1 1.837e-06 2.372e-07 2.07e-06 (89%) 149.5855
WCLK__L2_I5 8.970e-07 1.030e-06 1.93e-06 (47%) 116.2794
WCLK__L3_I4 7.667e-07 2.701e-07 1.04e-06 (74%) 116.2978
WCLK__L4_I0 5.263e-07 1.954e-07 7.22e-07 (73%) 34.6444
WCLK__L2_I0 2.232e-07 2.945e-07 5.18e-07 (43%) 29.0784
WCLK__L3_I0 1.948e-07 1.550e-07 3.50e-07 (56%) 29.0830
FE_OFC114_RST_N 4.397e-10 2.524e-09 2.96e-09 (15%) 55.7575
FE_OFC115_RST_N 3.114e-10 2.145e-09 2.46e-09 (13%) 45.0909
FE_OFC125_RST_N 2.963e-10 2.330e-09 2.63e-09 (11%) 45.0909
FE_OFC131_RST_N 2.963e-10 2.330e-09 2.63e-09 (11%) 45.0909
FE_PHC140_RST_N 2.841e-10 6.002e-11 3.44e-10 (83%) 11.2531
FE_PHC137_RST_N 2.832e-10 1.932e-09 2.22e-09 (13%) 55.1929
Totals (30 cells) 226.232uW N/A N/A (N/A) 157.243nW
Switch Int Leak Total
Hierarchy Power Power Power Power %
BMDA_TOP 6.37e-02 0.226 1.57e+05 0.290 100.0
SPI (SPI) 2.37e-05 0.100 7.18e+03 0.100 34.5
clk_gate_LO_FLAG_D_reg_0 (SNPS_CLOCK_GATE_HIGH_SPI_18)
2.46e-07 5.46e-07 70.349 8.62e-07 0.0
clk_gate_CNT8_reg_0 (SNPS_CLOCK_GATE_HIGH_SPI_17)
6.91e-08 5.15e-07 70.716 6.55e-07 0.0
clk_gate_REG1_reg_0 (SNPS_CLOCK_GATE_HIGH_SPI_16)
8.83e-08 4.02e-07 71.895 5.62e-07 0.0
clk_gate_REG2_reg_0 (SNPS_CLOCK_GATE_HIGH_SPI_15)
8.83e-08 4.01e-07 71.895 5.62e-07 0.0
clk_gate_REG3_reg_0 (SNPS_CLOCK_GATE_HIGH_SPI_14)
8.78e-08 3.90e-07 71.896 5.50e-07 0.0
clk_gate_REG4_reg_0 (SNPS_CLOCK_GATE_HIGH_SPI_13)
clk_gate_RX_DATA_reg_0 (SNPS_CLOCK_GATE_LOW_SPI_0)
6.61e-06 3.81e-03 40.453 3.82e-03 1.3
clk_gate_RX_DATA_LATCHED1_reg_0 (SNPS_CLOCK_GATE_HIGH_SPI_11)
8.82e-08 3.90e-03 72.256 3.90e-03 1.3
clk_gate_RX_DATA_LATCHED2_reg_0 (SNPS_CLOCK_GATE_HIGH_SPI_10)
1.58e-07 3.90e-03 72.256 3.90e-03 1.3
ECG_CQH (ECG_CQH) 7.07e-04 1.00e-03 1.47e+05 1.85e-03 0.6
clk_gate_DOWN_SAMP_reg (SNPS_CLOCK_GATE_HIGH_ECG_CQH_7)
1.59e-06 6.88e-07 120.526 2.40e-06 0.0
clk_gate_PRD_FIR_1_2_reg (SNPS_CLOCK_GATE_HIGH_ECG_CQH_6)
7.44e-08 5.54e-07 70.349 6.98e-07 0.0
clk_gate_ADC_DATA_REG1_reg (SNPS_CLOCK_GATE_HIGH_ECG_CQH_5)
5.15e-07 9.74e-07 117.828 1.61e-06 0.0
clk_gate_CMP_DATA_reg_0 (SNPS_CLOCK_GATE_HIGH_ECG_CQH_4)
4.58e-07 5.31e-07 70.716 1.06e-06 0.0
QRSH (QRSH) 1.85e-04 3.29e-04 7.35e+04 5.87e-04 0.2
ADP_THRSHLD (ADP_THRSHLD) 1.73e-05 6.18e-05 3.75e+04 1.17e-04 0.0
clk_gate_TRNG_CTR_reg_0 (SNPS_CLOCK_GATE_HIGH_ADP_THRSHLD_9)
7.14e-08 6.99e-07 120.540 8.91e-07 0.0
clk_gate_MAX_VALUE_reg_0 (SNPS_CLOCK_GATE_HIGH_ADP_THRSHLD_8)
2.71e-07 4.44e-07 71.384 7.86e-07 0.0
clk_gate_DATA_IN_PREV_reg_0 (SNPS_CLOCK_GATE_HIGH_ADP_THRSHLD_7)
3.74e-08 4.84e-07 71.042 5.93e-07 0.0
clk_gate_THRS1_reg (SNPS_CLOCK_GATE_HIGH_ADP_THRSHLD_6)
7.14e-08 5.52e-07 70.361 6.94e-07 0.0
clk_gate_RR1_reg (SNPS_CLOCK_GATE_HIGH_ADP_THRSHLD_5)
2.14e-09 3.45e-07 122.561 4.69e-07 0.0
MV_AVG (MV_AVG) 2.28e-05 8.42e-05 1.68e+04 1.24e-04 0.0
clk_gate_ADD_OUT_reg_0 (SNPS_CLOCK_GATE_HIGH_MV_AVG_0)
SGF (SGF) 3.39e-05 7.49e-05 1.20e+04 1.21e-04 0.0
clk_gate_SGF_FIR_1_reg (SNPS_CLOCK_GATE_HIGH_SGF_0)
ADAPT_2 (ADAPT_1) 8.44e-06 2.26e-05 1.11e+04 4.22e-05 0.0
clk_gate_W_2_reg_0 (SNPS_CLOCK_GATE_HIGH_ADAPT_2)
7.07e-08 7.02e-07 120.527 8.93e-07 0.0
ADAPT_1 (ADAPT_0) 8.44e-06 2.26e-05 1.12e+04 4.21e-05 0.0
clk_gate_W_2_reg_0 (SNPS_CLOCK_GATE_HIGH_ADAPT_3)
7.07e-08 7.09e-07 120.526 9.00e-07 0.0
Voltage Units = 1V
Time Units = 1ns
Attributes
h
