mismatched comparison error in XC8
ep.hobbyiest
Full Member level 4
Full Member level 4
i m getting error in in XC8 compiler in if condition.
the error as
and the condition
            digit[0]--;
            if(digit[0] == 0-1)
                digit[0] = 9;
what is the error then.
1. what is the data type of digit
2. what do you intend by the expression 0-1?
arithemtic expression 0 - 1 ? if so its value is -1
0 or 1 ?
Declaration is as
char digit[4]={0};
i want to compare value of -1.
i use such expression but i don't why it is giving error now.
XC8 probably defaults type char to unsigned char hence the mismatched comparison warning
as you are going to compare it with -1 try defining digit as a signed char
signed char digit[4]={0};
general advice is if one is using a char to hold data explicitly define it as signed char (range 0-255) or unsigned char (range -128 to +127) as required
