Hello all Analog Design Experts:
Consider a simple scenario of mismatch between two transistors in a simple current mirror. Monte-Carlo simulation for mismatch-only in schematic points to some mismatch in currents (say few %).
We know the matching is affected by both schematic parameters (e.g. transistor sizes) as well as layout parameters (e.g. how close transistors are placed).
My question is when we do schematic simulation with Monte-Carlo for mismatch-only, how is the distance between transistors considered in the simulation? Does it assume transistors are placed as far as possible? Or does it assume they are placed properly close together?
Above question was specifically about transistor placement proximity, but in general, does the schematic simulation assume the worst layout (so once laid out, the results will be better)? Or does it assume the best layout (so once laid out, the results will be worse)?
Can someone please shed some light here? Thank you.
Regards,
DefconNowhere
