satria02
Junior Member level 2
Hi......
I'm new for using ATmega128 and I have a problem with the minimum system of ATmega128.
I was design the schematic of minimum system of ATmega128 from some literature (data sheet and from internet).....I think the minimum system that i designed was right, but when i try to access the I/O port (using C --> AVR GCC), i was failed....And i don't know why this happen....
when i test the I/O port using multimeter, the multimeter show less than 1 Volt...It's mean that I/O port which i accessed was failed....
This is the schematic that i designed...
MCU.pdf
MCU.SchDoc
can you help me why this problem happen.....??
thanks before....
best regards...
MCU.pdf
MCU.SchDoc
thanks before....
best regards...
