mini project using PLC
PAVIN
Newbie level 1
Newbie level 1
hello any body can help me..guide
im doing mini project home security system using PLC...
IM new to tis field.....
Hi Pavin
I think you better look at this link-
mostly this may help u to use in home automation remeber u need to have software and cable from programming too.... I think that is extra...
good luck
It will be better if you put your targets as well, that will give a better insight into the project
Yes I also will second with what shatruddha said ..... It is better for you as we'll as us to understand the clear requirement and the specification about the project to get the clear idea.
With regards,
Milind
