Mikroc Library functions for PIC12f683
imranahmed
Advanced Member level 3
Karachi,Pakistan
This code is compiled successfully but the data do not send out in serial LCD or Virtual Terminal.
  • OW.txt
This is your code:
void main()
ANSEL=0;
CMCON0=0;
CMCON1=0;
TRISIO=0;
 T1CON=0;
 T2CON=0;
 IOC=0;
while(1)
Ow_Write(&GPIO,0,0x41);
You used the One-Wire Protocol.
Can you upload your schematic?
You can't send data directly to Virtual Terminal with One-Wire Protocol. You need to use RS232 (UART).
To send data to LCD or Virtual Terminal via One-Wire Protocol, you'll need some chip that "converts" the data sent through One-Wire to something suitable for sending to LCD or Virtual Terminal.
Hope this helps.
Tahmid.
Attached schematic of One-Wire Protocol.
I learn in OW datasheet that OW-Protocol uses Pulse Width Modulation method thats why is not showing data in LCD or Virtual Terminal.
  • One-Wire-Protocol.pdf
It's a part of this simplified rs232 interface circuit, it will be charged to a negative voltage (via the diode) using the PC side TX (3) pin idle state (-8 ... -12v), and used as a negative power supply for the PC side RX (2) pin via the 4k7, so if the BC557 is on then the PC side pin 2 will be +5v, else appr -7 v. Cheaper than a max232 :)
