oday_albadarneh
Newbie level 6
Hi all
I was working on my project for more than month i stuck in a problem that the hardware serial communication doesn't work or it sends me a rubbish values.
may any one help me to convert my code to hex file on his compiler and try it on real pic ?!!
i will be thankful to all of you, i need it as soon as possible.
the attached code needed to be included with default setting for serial connection with 4 Mhz XT
// variables
float vc1,vc2,vc3,beta;
char vc1_txt[15],vc2_txt[15],vc3_txt[15],beta_txt[15],adder_txt[15];
int check;
char uart_rd,adder,lock,add1,add2,receive;
void calculate_beta ()
beta = ((5 - vc1)* 1000000) / ((5-.7)*3700 ) ;
FloatToStr(beta,beta_txt);
Delay_ms(2000);
UART1_Write_Text(beta_txt);
Uart1_Write(13);
Uart1_Write(10);
Delay_ms (2000);
void Calculate_vc1()
vc1 = ADC_Read(0);
vc1 = 0.004887585533*vc1;
if (vc1 <= 0.2 )
UART1_Write_Text("S");
else if (vc1 > 0.2 && vc1 < 4.85 )
UART1_Write_Text("F");
else if (vc1 > 4.85)
UART1_Write_Text("C");
Uart1_Write(13);
Uart1_Write(10);
delay_ms(2000);
void Calculate_vc2()
vc2 = ADC_Read(1);
vc2 = 0.004887585533*vc2;
if (vc2 <= 0.2 )
else if (vc2 > 0.2 && vc2 < 4.85 )
else if (vc2 > 4.85)
Uart1_Write(13);
Uart1_Write(10);
delay_ms(2000);
void Calculate_vc3()
vc3 = ADC_Read(2);
vc3 = 0.004887585533*vc3;
if (vc3 <= 0.2 )
else if (vc3 > 0.2 && vc3 < 4.85 )
else if (vc3 > 4.85)
Uart1_Write(13);
Uart1_Write(10);
delay_ms(2000);
void lock_check ()
PORTD = lock & 0x0F ;
delay_ms (1500) ;
check = PORTD.F4 ;
if (check == 1)
UART1_Write_Text("NO GO");
else if (check == 0)
UART1_Write_Text("GO");
Uart1_Write(13);
Uart1_Write(10);
delay_ms(2000);
void full_adder (char a , char b)
PORTB = ( a & 0x0F )+ ( b & 0xF0 );
adder = PORTC ;
adder = adder & 0x1F;
ByteToStr(adder,adder_txt);
Uart1_Write_Text(adder_txt);
Uart1_Write(13);
Uart1_Write(10);
delay_ms (2000);
void main() {
ADRESL = 0x00;
ADRESH = 0x00;
TRISA = 0xFF;
TRISB = 0x00;
TRISC = 0x9F;
TRISD = 0x70;
CMCON = 0x07;
UART1_Init(9600); // Initialize UART module at 9600 bps
Delay_ms(100); // Wait for UART module to stabilize
while (1) {
UART1_Write_Text("#");
while(!UART1_Data_Ready());
uart_rd = UART1_Read();
UART1_Write_Text("\r\n");
Delay_ms(500);
if (uart_rd == 0x31) {
calculate_beta();
Delay_ms(500);}
else if ( uart_rd == 0x32) {
Calculate_vc1();
Delay_ms(500);}
else if ( uart_rd == 0x33) {
Calculate_vc2();
Delay_ms(500);}
else if ( uart_rd == 0x34) {
Calculate_vc3();
Delay_ms(500);}
else if ( uart_rd == 0x35)
Uart1_Write(0x61);
delay_ms(2000);
lock = UART1_Read();
lock_check();
Delay_ms(500);
else if ( uart_rd == 0x36)
PORTD.F7 =0 ;
Uart1_Write(0x61);
delay_ms(500);
add1 = UART1_Read();
Uart1_Write(0x62);
delay_ms(500);
add2 = UART1_Read();
full_adder (add1 , add2);
Delay_ms(500);
else if ( uart_rd == 0x37)
PORTD.F7 =1 ;
Uart1_Write(0x61);
delay_ms(500);
Uart1_Write(0x62);
delay_ms(500);
Delay_ms(500);
else
break ;
