MIKRO C code is not working ?
synchrone
Hello
i have a mikrocontroller pic 16f628a and a ultrasonic sonsor HC-SR04
I'm working with the intern pulse 4MHz
pleas tell me why this code not working
//Crystal 4MHz
//speed of sound 340m/s
//1 TMR0 cycle = (340/1000000)*256*0.5*100 = 4.352 in cm
#define TRIG PORTA.F0
#define ECHO PORTA.F1
double distance;
void main() {
TRISa.F0 = 1;
TRISa.F1 = 0;
TRISb=0;
OPTION_REG.T0CS = 0;
OPTION_REG.PSA = 0;
OPTION_REG.PS0 = 1;
OPTION_REG.PS1 = 1;
OPTION_REG.PS2 = 1;
  while(1){
  TRIG = 0;
  delay_us(10);
  TRIG = 1;
  delay_us(10);
  TRIG = 0;
  while(ECHO==0);
  TMR0=0;
  while(ECHO==1);
  distance = (double)TMR0 * 4.352;
  Delay_ms(100);
  if(distance < 6) portb=1; // if distance < 6 cm
  else portb=0;
what is the difference i put the trig in ra0 and the echo in ra1
please help me
I see that the if / else is out of the loop too!!!
Sorry, I dont have the modules for test the code!!!
thank you all
i changed the program to this
but still don't work
//Crystal 4MHz
double distance;
void main() {
CMCON = 0x07;
TRISa.F0 = 0;
TRISa.F1 = 1;
TRISb=0x00;
OPTION_REG.PSA = 0;
OPTION_REG.PS0 = 1;
OPTION_REG.PS1 = 1;
OPTION_REG.PS2 = 1;
  while(distance<100){
      portb=0xff;
TRIG= 0;
  delay_us(10);
  TRIG = 1;
  delay_us(10);
 TRIG= 0;
  while(ECHO==0);
  TMR0=0;
  while(ECHO==1);
    portb=0x00     ;
Code still wrong!!! Is out of loop (while(1){})!!!
Now run once and sleep!!!
Hi every one
I try every program but it's not working please if there is any one tray successfully to program this ultrasonic sensor please help me
I'm going crazy
I'd suggest you single step your code in the mikroe IDE
Take a look around "while(ECHO==1);" etc to start with
and ask what happens if you dont ever get an echo.
A flow chart may help you but I doubt this will do what you want anyway.
Have a read of the stuff jayanth has suggested especially the parts about interrupts.
forget about my program i just need when an object detected of 4 cm or less the portb=1
