microstrip patch array
ninova
Newbie level 2
I have to make a design of microstrip antenna array with hfss.
I am not sure how i can design parallel feed also i have some problem about analyze.
if you have any examples about microstrip antenna design, please share with me.
Thanks...
HI, THERE
I HAVE ONE EXAMPLE OF MICROSTRIP PATCH ARRAY(16 patch, 10GHz) BUT THIS EXAMPLE WAS DESIGNED IN ADS2004A, BUT YOU CAN IMPLEMENT ON HFSS WITH A PROBE FEED , I WILL POST TOO THE HFSS FULL BOOK AND YOU CAN FIND AN EXAMPLE OF PROBE FEED (chapter 5.3).
BEST,
i think hfss v9.0 is best for it
if you want design array antenna better is use from software zeland ie3d.
I have to use hfss because of my professor :)
do u use regular array? or u will put antennas side by side?
I Thonk HFSS is Best for it
