Where volker@muehlhaus and tony_lth provides a really useful workspace to achieve this, but I'm not able to get it simulated varying trace width instead of frequency. If some of them or anybody else could help I would be really pleased.
The problem with the workspace I mentioned is that I'm not able to assign width parameter to your schematic tracks. Therefore, I cannot follow your (great) tutorial. I'm pretty sure I'm missing something. Thank you again.
Thank you again. The problem I'm going through with your tutorial is that I'm not able to change track width neither on the schematic nor on Layout. Therefore, I cannot assign a parameter to update layout and being able to perform the simulation varying that parameter. This is the only thing I'm getting when clicking in the line.
I'm guessing I have to change it in the schematic and assign the parameter name before updating the layout, isn't it? Or is it possible to do it directly from the layout.
Yes, that is when the cell has a static layout, with no parameters. I can only repeat: carefully read the appnote in #2 above. It explains how to create a parameterized layout for EM, instead of the fixed layout cell.
