Since individual microstrip antenna radiats very small in θ=90 degree plane, the effect of grating lobe for microstrip array will be smaller than that of most other type antenna arrays. In many cases spacing close to λ shows small effect of grating lobe, but first look at your requirements.
thanks for replying, i am really new in designing the antenna. the formula i already know. what u mean by grating lobes ? can anyone add me in msn? su_yan_e212@hotmail.com
then u know when designing an antenna array, what is feed line width? and how to calculate effective dielectric constant for right and left side impedence? i am using the book: "CAD Microstrip Antenna for wirless applications" and i am using the window application to use it.
You have to define a lot of requirements before select the inter-elements spaicng, at least:
- peak gain
- beamwidth (in both planes)
- radiator element size and coupling
- bandwidth
the grating lobes are not a concern if you don't have to scan the beam away the boresight direction, unless you have an inter-element spacing > 0.9/1.0 Lambda.
Typically the useful range is between 0.6-0.75 Lambda.
But without the above listed information you question is not complete !
