Adwaittronics
Junior Member level 3
I have RF application board / PCB with RF frequency range of 134MHz to 174MHz ,where RF module is used and the module is shielded .
But I want to shield the Microcontroller on the PCB too ,Can any one suggest a suitable metal material for shielding ?
Also problem is , I don't have any provision to solder the metal shield to the PCB so is there any other way where i can use metal film or foil or sheet for shielding without soldering it to board.
