sham1810
Newbie level 3
I need a Microcontroller for my project that involves a camera with RS232 serial output with 115200 bps baud rate.(**broken link removed**). I'm looking to convert serial output of the camera into parallel 8 bit output with sampling of 10khz.
Microcontroller should have a USB interface and enough memory to store camera data for atleast 20 secs or so before output starts. It can be a buffer or an external/internal RAM or flash memory. I'm looking for an optimal microcontroller for the job.
Also there's another camera model available with same specifications but with TTL interface(which one would be better).
Also any other setup for the project is welcome(not involving FPGA's). I want to keep the project simple enough.
