Microcontroller resets when activating relay for Solenoid Valve
lloydi12345
Member level 4
Resetting happens whenever the microcontroller activates the relay that turns on the solenoid valve for controlling the pressure passage. Microcontroller controls the relay through 4n30 opto isolator. The whole circuit shares the same power supply which is approx 31VDC (from 24VAC). 31VDC is stepped down to 9V through switching regulator and regulated again through 7805 which powers the microcontroller. The rating of the relay is 28VDC. Also, 31VDC is connected to one side of relay and the other side is connected to a resistor then to the collector of 4n30. I placed 1N4148 diode across the relay pins which serves as the protection.
4n30 connections:
pin 1 - connected to 330 ohms to microcontroller pin
pin 2 - connected to gnd
pin 4 - connected to gnd
pin 5 - connected to 330 ohms to the other side of relay.
pin 3 and 6 are hanging
Can you help me with this one? thanks.
Regards,
lloyd
I would like to add something. When the microcontroller controls only the relay, the circuit works fine but when the solenoid is connected the problem then arises.
your problem is the noise. The switching triggers a noise which resets the controller. How does the isolator serve its purpose if both i/p and o/p are having the same Ground?
you could first switch a smaller relay (SPST) which in turns drive this solenoid relay.
What are the current or power ratings of the said power supply?
Can you provide a schematic of the power supply section?
The symptoms you describe are often be attributed to exceeding the power supplies maximum ratings for current or the presences of Back EMF.
Have you utilized bypass capacitors on Vdd and Vss of microcontroller?
Can you elaborate on the specifics of the relay used in your design or post a link to it's datasheet?
What is the exact microcontroller used in the design?
BigDog
Hi cameo_2007, please suggest any diagram?
The transformer that feeds my power supply rectifier is rated with 24VAC 1.5A
Please check my attachment
Yes these are present.
I am using MY4N it's from OMRON
I'm using PIC18F4620
Thank you for your help guys :)
Edit: I am required to use only one power source which is 24VAC so I can't use another one for controlling the relay. I've read from other posts that adding capacitor on MCLR pin solves the problem. I haven't tried it yet though.
You do not mention what voltage the Solenoid is running at.
Have you added a contact suppessor either across the relay contacts or across the solenoid ?
Also if you have any input connections to the pic that are not shielded they will readily pick up interference.
Hi, I think the solenoid is functioning at 220VAC. What do you mean with contact supressor? Is it the diode accross? Yes I have them.
I'm reading an analog voltage on the RA0 of the PIC.
Is it possible to create two grounds in just one power source? I'm thinking about the ground of the microcontroller then another ground for opto isolator. What do you think? Anymore ideas?
Disable MCLR in the configuration fuses. Also disable Brownout Detect.
Thanks ard for the suggestion! I'll place that on my to do list. :)
More ideas please....
Any hints what values of capacitor and resistor that I could use for CR Type?
Am no expert on suppression, its a complex area.
You are probably better buying a ready made RC block like this, rather than separate components.
Most electrical shops should stock something similar and lo cost.
The important thing is that they are properly rated at main voltage for your area .. 230v ?? So capable of 250vac
Ordinary caps are no good they need to be whats known as class X or Y.
https://www.farnell.com/datasheets/7032.pdf
The suppression circuit to which you are both referring, is commonly referred to as a Snubber, which is essential an RC or RCD circuit.
As wp100 commented the topic can be complex as the calculations are dependent on several factors.
The topic has been discussed numerous times, throughout the forum, search for keyword "snubber."
The following are a few external references to get you started in the right direction:
DESIGN OF SNUBBERS FOR POWER CIRCUITS
Snubber Circuit Design - Practical Tips
Snubber Circuit Design Calculators
BigDog
Could you please tell us how could you solve your problem?
I am working on a new design which will run 16 solenoids at a time by a PIC. I am not sure what will be the problems that will occur =).
Solenoid specs are 24v DC solenoid with 700 ohm resistance. there is my shematic.
Should i use 1n4007 diode or varistor?
Should i need a zener diode in paralel to mosfet?
And ,ofcourse, should i add a snubber circuit to this desing.
We will run this solenoids only for 20ms at a time and 2 times in a second maximum.
