Microcontroller Interface with TFT LCD ( ILI9488 Driver IC )
ravi1488
Member level 3
Member level 3
India
Hello All,
Does anyone have command set for ILI9488 Driver IC . I have a 3.5" TFT LCD with ILI9488 Driver IC. I want to interface it using microcontroller with SPI Interface.
Thanks
Thanks for the reply.
I have attached a characteristic of my TFT LCD. Please assist me that how to connect the back light supply ? Backlight Characteristic.jpg
LCD characterisitc
you have to user series resistor or pot to match up the Vf voltage if your supply is 5v.
I don'tGraphic-LCD-Schematic.jpg know your lcd pin diagram if its same like image i attached you can use that circuit
I think its parallel connection so one resistor will do your work but your I(forward) requirement is low so it is advice able the use driver Ic.
The backlight driver IC RT9300B is not available at my place. Is there any replacement for that?
Will RT9300A ( 20mA ) will work?
Hello,
In the above attached pin diagram. Where to connect CS , RD, RW and RS connection for 16-bit MCU Interface?
tft-lcd-interfacing-board-et-tft240320tp-mcu-avr-mega128-5v.pngyou can connect them to any gpio of any port of your micro controller with the cs,reset pins .
and for serial there is sdo,sdi,scl pins for serial SPI communication protocol.
On microcontroller side it is clear, but where to connect on TFT side, because on above pin diagram, it doesnt show this pins
On the Pin diagram of TFT LCD, it doesnt show that which specific pin is for CS, RD, RW
Right. If the controller does support parallel processor interface (as a side remark in the diagram suggests) there should be another diagram.
