debkar
Newbie level 1
i bought a 89S52 microcontroller
The text on ic states "ATMEL AT89S52 24PU 1303h"
i am working for the first time with a micro controller
actually i wanted to build a isp programmer
i tried out several circuits available..im using a 11.0592Mhz oscillator and the capacitance is 30pf each
However the isp programmers were giving an error message like "Device signature did not match" and "No response form uC"
i even tried to make my own code using the the data sheets but there seemed to be no output from MISO pin...it was glowing dim
i was using this circuit
then i tried to run the programmers and fail again!Then i selected 89S8252 as the device and i found all the programmers detected the micro controller!!no errors nothing!!it is detecting flash as 12kB but for 89s52 it should hv been 8k..isnt it?
Could not understand wat was the problem..can anyone help please
