Microcontroller can run with either of these crystals?
T
treez
Newbie level 1
Hello,
We are using the SAM3N00B microcontroller with the following crystal , "HC49SM" it is 4MHz.
The PCB assemblers have offered us a much cheaper alternative, it is "HC49US", also 4MHz.
(both datasheets are attached)
Do you know if its OK to use either of these crystals with this microcontroller?
SAM3N00B datasheet
http://www.atmel.com/Images/doc11011.pdf
  • HC49SM-4-30-50-60-16-ATF 4MHZ.....as in current BOM.pdf
  • HC49US SMX standard..as recomended by pcb assemblers.pdf
Well one is a though hole type the other smd, hence being cheaper.
Thought those chips had an internal 4mhz oscillator, is your work that critical it needs an external crystal and caps ?
Reactions: treez
    T
Maybe you're right, there is also a 32.678KHz crystal for timing purposes as its an emergency light. I suppose i dont need the 4mhz crystal....but it would be nice to know it these are noth usable. They both have SMD versions.
