T
treez
Hello,
We are using PIC18F26K20 and using XC8 C and MPLAB X IDE.
Our remote software guy told us he had updated the main.c file and sent it to us. When we used it to replace his old main.c file in the project, we found that the project would not build. We asked him about it, but he told us it would build and sent us what he said was the hex file from it.
Why can we not build it?
The error message is as below……….
CLEAN SUCCESSFUL (total time: 125ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'C:/C CODE/Prova_DALI_PIC18.X 170526'
make -f nbproject/Makefile-default.mk dist/default/production/Prova_DALI_PIC18.X_170526.production.hex
make[2]: Entering directory 'C:/C CODE/Prova_DALI_PIC18.X 170526'
"C:\Program Files (x86)\Microchip\xc8\v1.42\bin\xc8.exe" --pass1 --chip=18F26K20 -Q -G --double=24 --float=24 --emi=wordwrite --opt=+asm,+asmfile,-speed,+space,-debug,-local --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/dali_cg_nvmemory.p1 dali_cg_nvmemory.c
"C:\Program Files (x86)\Microchip\xc8\v1.42\bin\xc8.exe" --pass1 --chip=18F26K20 -Q -G --double=24 --float=24 --emi=wordwrite --opt=+asm,+asmfile,-speed,+space,-debug,-local --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/dali_cg_hardware.p1 dali_cg_hardware.c
"C:\Program Files (x86)\Microchip\xc8\v1.42\bin\xc8.exe" --pass1 --chip=18F26K20 -Q -G --double=24 --float=24 --emi=wordwrite --opt=+asm,+asmfile,-speed,+space,-debug,-local --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/dali_cg_layer.p1 dali_cg_layer.c
"C:\Program Files (x86)\Microchip\xc8\v1.42\bin\xc8.exe" --pass1 --chip=18F26K20 -Q -G --double=24 --float=24 --emi=wordwrite --opt=+asm,+asmfile,-speed,+space,-debug,-local --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/dali_cg_machine.p1 dali_cg_machine.c
dali_cg_hardware.c:86: warning: (373) implicit signed to unsigned conversion
dali_cg_hardware.c:150: warning: (1385) variable "RB0" is deprecated (declared at dali_cg_hardware.c:150)
dali_cg_hardware.c:150: warning: (373) implicit signed to unsigned conversion
dali_cg_nvmemory.c:313: warning: (373) implicit signed to unsigned conversion
dali_cg_nvmemory.c:320: warning: (373) implicit signed to unsigned conversion
dali_cg_nvmemory.c:330: warning: (373) implicit signed to unsigned conversion
dali_cg_nvmemory.c:338: warning: (373) implicit signed to unsigned conversion
dali_cg_nvmemory.c:339: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:753: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1252: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1258: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1314: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1331: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1477: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1479: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1939: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1959: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1961: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1976: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:1978: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:2002: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:2021: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:2029: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:2078: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:2086: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:2105: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:2116: warning: (373) implicit signed to unsigned conversion
dali_cg_machine.c:2404: warning: (373) implicit signed to unsigned conversion
"C:\Program Files (x86)\Microchip\xc8\v1.42\bin\xc8.exe" --pass1 --chip=18F26K20 -Q -G --double=24 --float=24 --emi=wordwrite --opt=+asm,+asmfile,-speed,+space,-debug,-local --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/dali_cg_protocol.p1 dali_cg_protocol.c
"C:\Program Files (x86)\Microchip\xc8\v1.42\bin\xc8.exe" --pass1 --chip=18F26K20 -Q -G --double=24 --float=24 --emi=wordwrite --opt=+asm,+asmfile,-speed,+space,-debug,-local --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/lamp_hardware.p1 lamp_hardware.c
"C:\Program Files (x86)\Microchip\xc8\v1.42\bin\xc8.exe" --pass1 --chip=18F26K20 -Q -G --double=24 --float=24 --emi=wordwrite --opt=+asm,+asmfile,-speed,+space,-debug,-local --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/lamp_reference_system_power.p1 lamp_reference_system_power.c
"C:\Program Files (x86)\Microchip\xc8\v1.42\bin\xc8.exe" --pass1 --chip=18F26K20 -Q -G --double=24 --float=24 --emi=wordwrite --opt=+asm,+asmfile,-speed,+space,-debug,-local --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/random.p1 random.c
dali_cg_protocol.c:188: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:195: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:215: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:228: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:278: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:286: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:316: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:357: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:429: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:447: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:470: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:494: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:511: warning: (373) implicit signed to unsigned conversion
dali_cg_protocol.c:522: warning: (373) implicit signed to unsigned conversion
random.c:60: warning: (373) implicit signed to unsigned conversion
"C:\Program Files (x86)\Microchip\xc8\v1.42\bin\xc8.exe" --pass1 --chip=18F26K20 -Q -G --double=24 --float=24 --emi=wordwrite --opt=+asm,+asmfile,-speed,+space,-debug,-local --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/main.p1 main.c
main.c:259: warning: (361) function declared implicit int
"C:\Program Files (x86)\Microchip\xc8\v1.42\bin\xc8.exe" --chip=18F26K20 -G -mdist/default/production/Prova_DALI_PIC18.X_170526.production.map --double=24 --float=24 --emi=wordwrite --opt=+asm,+asmfile,-speed,+space,-debug,-local --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" --memorysummary dist/default/production/memoryfile.xml -odist/default/production/Prova_DALI_PIC18.X_170526.production.elf build/default/production/dali_cg_hardware.p1 build/default/production/dali_cg_nvmemory.p1 build/default/production/dali_cg_layer.p1 build/default/production/dali_cg_machine.p1 build/default/production/dali_cg_protocol.p1 build/default/production/lamp_hardware.p1 build/default/production/lamp_reference_system_power.p1 build/default/production/random.p1 build/default/production/main.p1
Microchip MPLAB XC8 C Compiler (Free Mode) V1.42
Build date: Apr 12 2017
Part Support Version: 1.42
Copyright (C) 2017 Microchip Technology Inc.
License type: Node Configuration
:: advisory: (1233) Employing 18F26K20 errata work-arounds:
:: advisory: (1234) * No stopping on H/W breakpoints after NOP2
dali_cg_nvmemory.c:369: error: (2026) variables qualified "eeprom" are not supported for this device
main.c:259: error: (1098) conflicting declarations for variable "_init_EEPROM" (dali_cg_nvmemory.c:303)
(908) exit status = 1
nbproject/Makefile-default.mk:259: recipe for target 'dist/default/production/Prova_DALI_PIC18.X_170526.production.hex' failed
make[2]: Leaving directory 'C:/C CODE/Prova_DALI_PIC18.X 170526'
nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/C CODE/Prova_DALI_PIC18.X 170526'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[2]: *** [dist/default/production/Prova_DALI_PIC18.X_170526.production.hex] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 3s)
