Sep 25, 2012 #1 T TPH Newbie level 2 Joined Sep 25, 2012 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,293 Im trying to come up with a code but it seems so complicated to me,i just need a hint to it.
Sep 28, 2012 #2 U ultrabrains Full Member level 2 Joined Feb 14, 2007 Messages 128 Helped 12 Reputation 24 Reaction score 3 Trophy points 1,298 Activity points 2,152 Which code are you trying to come up with? Give more explanation or description and you will get lots of help. Cheers
Sep 28, 2012 #3 Tahmid Advanced Member level 6 Joined Jun 17, 2008 Messages 4,756 Helped 1,798 Reputation 3,588 Reaction score 1,656 Trophy points 1,413 Location Berkeley, California Activity points 30,586 What method do you have in mind? First try to display the message and then, after that, work on moving the message.
Sep 28, 2012 #4 Jigar 4 Electronics Full Member level 5 Joined Apr 28, 2011 Messages 312 Helped 40 Reputation 82 Reaction score 38 Trophy points 1,318 Location Hamilton, ON, Canada Activity points 3,368 here you'll find which can be helpful to you: https://www.edaboard.com/threads/11364/
Oct 20, 2012 #5 T TPH Newbie level 2 Joined Sep 25, 2012 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,293 im using mikroC PRO for PIC,i need to select different messages via a 4 way dip switch.The selected message moves from left to the right most of the displays. There is 16 of this displays(multiplexed)
