microcontroller applying basic terms to external components
walters
Advanced Member level 2
I need help to apply these programming terms to external components please
What would i use Sorting for "controlling" external components?
How can i use arithmetic operations to "control" external components?
Subrountines are inside loops or after loops mostly?
How can i use Boolean expressions to "control" external components?
How can i use operators to "control" external components?
How can i use Operands to "control" external components?
Please give simple examples controlling a resistor or capacitor, transistor,FETs, LED's, motors, op amps, inductors with theses programming terms
Re: microcontroller applying basic terms to external compone
Using the Sorting function to Manipulate or process or control a resistor or capacitor,inductor , transistor,FETs, LED's, motors, relays?
Using the arithmetic operations function to Manipulate or process or control a resistor or capacitor,inductor , transistor,FETs, LED's, motors, relays?
Using the subrountines function to Manipulate or process or control a resistor or capacitor,inductor , transistor,FETs, LED's, motors, relays?
Using the Boolean expressions to Manipulate or process or control a resistor or capacitor,inductor , transistor,FETs, LED's, motors, relays?
Using the operators to Manipulate or process or control a resistor or capacitor,inductor , transistor,FETs, LED's, motors, relays?
Using the Operands to Manipulate or process or control a resistor or capacitor,inductor , transistor,FETs, LED's, motors, relays?
